LabWindows/CVI
NewAsyncTimer definition?
I'm searching for the defintion of the parameters for the function NewAsyncTimer()? I found it nowhere.
Perhaps somebody could say, where I can find it. Thx
kind regards
Florian
(3,628 Views)
Greber,
You can use the Async Timer function panel file to get the definitions for NewAsyncTime. To add the function panel, on your CVI main toolbar select Instrument->Load and navigate to 'C:\Program Files\National Instruments\CVI70\toolslib\toolbox\asynctmr.fp '(This is the default install dir for CVI, if your installation is in a different location the first couple directories in your path may differ slightly).
Once the function panel is loaded, you can click on the icon for the NewAsyncTime function and right-click on any of the parameters to see a description.
(3,621 Views)
thx I forgotten this way to get help
now I'm smarter ^^
Florian
(3,619 Views)
