LabWindows/CVI
New pannel within Menu Pannel
I  have created a uir in which menu are involved  as user can chose the any option on that menu but what I need  is when user chose any option it should go to new pannel .
EXAMPLE:
int CVICALLBACK PANNEL_1 (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
helloworld_handle= LoadPanel (main_handle, "my_pro.uir", PAN_1);
InstallPopup (helloworld_handle);
SetCtrlVal (helloworld_handle, PAN_1_COMNO , &comno); // value to be display
 SetCtrlVal (helloworld_handle, PAN_1_BAUND_RATE , &baund_rate); // baund _rate value to be display
int CVICALLBACK COMNO (int menubar, int menuitem, void *callbackdata, int panel)
switch (comno)
case 1:
printf("case 1 is working");
break;
case 2:
printf("case 2 is working");
break;
return(0);
break;// PANNEL_1
} // PANNEL_1
return 0; // PANNEL_1
}// PANNEL_1
PLEASE check whether it works .
(1,157 Views)
This framework cannot operate correctly: you cannot nest callback functions one into the other.
The correct way to write the code is:
FUNCTION 1:
	Load a panel
	Populate controls on the panel
	Display it with either DisplayPanel or InstallPopup
	Exit the function
MENUFUNCTION 1
	Exit the function
MENUFUNCTION 2
	Exit the fuction
(Write menu functions with appropriate commands as separate blocks of code)
After the first function is executed (and terminated) the panel will be on screen and CVI will sit in RunUserInterface processing events: when the user chooses a menu function, the corresponding callback function will be executed.
(1,127 Views)
