LabWindows/CVI
New numeric control
Hi, I'm using CVI 7.1 on Win XP pro. Ihave defined a new numeric control by using the NewCtrl() function.
I have defined it's type to HOT or VALIDATE, but the value can not be edited. I can only increment/decrement the value. What should I do, please help.
(4,357 Views)
It should not be a problem. I performed the same operation on a CVI 7.1 with Win XP Pro. and was able to get the desired result.
You can check for the set control type with:
GetCtrlAttribute (panel, ctrl_id, ATTR_CTRL_MODE, &value);
after you create the numeric control. Default is value == 1 (which is for type: HOT)
Dwivedi
(4,342 Views)
The problem appears only on panels that are part of TabControl created from Canvas.
The control is in HOT mode and its value can be incremented/decremented, but not edited.
Please suggest any solution.
(4,322 Views)
Hello shimonir,
Would it be possible for you to post example code demonstrating the incorrect behavior?
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(4,303 Views)
Hello again,
Actually, I just found your code posted on another thread.
Thanks.
Wendy L
(4,296 Views)
Look here here for my observations and sample program.
It appears that controls created by NewCtrl have a problem getting the focus.
(4,290 Views)
I just posted a sample program here (NewCtrl2.zip) with a work-around: use SetActivePanel and SetActiveCtrl to force focus to the new control.
(4,279 Views)
