LabWindows/CVI
Network variable in .NET aspx page
Hi All,
We have a Labwindows project which is using CVI SQL Toolkit to send data to MS SQL database. We need to retrieve this data and show it in a excel like table control which has functionalities like sorting column, adding dynamic column, etc. Since Labwindows did not have such a control, we decided to navigate to a web page when a button is clicked in Labwindows program. Now, I need to suspend the Labwindows program until user closes the webpage. Since for this I will need to communicate between webpage and labwindows program, I tried using Network Variable in Reader\Writer mode. I could find from the examples what I need to write in Labwindows. However, I could not figure out the webpage part. I will appreciate if someone can help me or give me an example for the code in aspx page.
Kanu
(4,293 Views)
Accepted by topic author Kanu
Although what you're asking can be done with components from Measurement Studio, it's going to be a lot of work to get the framework setup.
Before we go down that road though, I wanted to make sure that you'd seen the CVI table control.  It is very capable of sorting columns and adding columns dynamically.  I've attached a small example program doing both of these things.  Take a look, and let me know if there are still things you find it can't do.
NickB
(4,277 Views)
Thanks for your reply Nick. Actually, I felt that table control will indeed solve my probelm. But I am facing a new issue now. Basically, I want to retrieve columns from MS SQL database and bind it to table control dynamically. I searched CVI SQL Toolkit hlep and found out DBGetVariantArray and DBGetVariantArrayColumn will help me to retrieve columns from result sets obtained from database query. Until an hour ago, I was able to obtain an int column from the database. Somehow, it throws General Protection Fault error now. I will appreciate if someone can suggest why is this problem happening.
Kanu
(4,275 Views)
I was having this problem because I was giving wrong address to retrieve string column from the database. Never mind. Looks like I have solved my problem.
Kanu
(4,272 Views)
