LabWindows/CVI
Network survey
How can I detect the plug state of my network wire, as Windows does ?
Thank you.
(3,305 Views)
Hey Nico,
  I haven't needed to do it yet, but it would be good to know.  So, here is a link that I found:
http://www.mobilizedsoftware.com/contributors/intel/naciriwp.jhtml
  Now, you have to compile with VC++ or similar to make the DLL--if you want to use his exact code.  Otherwise, at the bottom of the article there is a concept summary that you might be able to implement on your own with a little experimentation.  The answer is certainly yes, and this guy's method sounds pretty well founded in the API.
Orlan
(3,284 Views)
I'm going to see.
Thanks.
(3,273 Views)
