LabWindows/CVI
Need help with FFT
I have a 1D array that contain a SineWave, I would like to perform a FFT for this array and to plot it on a graph, but I don't know how to use the FFT function in the advanced analysis. What do I need to do ? Can somebody help me ?
Thank you,
Aldrin,
(2,972 Views)
Hello
If you will be using FFT alot, I suggest you read thru some basic theory to get you started. Here is a good site that can help you get started.
You can also check out the examples installed at ..CVI\samples\analysis.
Bilal Durrani
NI
Bilal Durrani
NI
(2,971 Views)
