LabWindows/CVI
NON FATAL RUN TIME ERROR
HI,
I"m running TS 3.5 + CVI8.01 in debug mode.
I get a window with the above message on the first line.
2nd line - Unkown source position, thread id 0x00000A20
3rd line - Uninitialized string
I don't see
(4,147 Views)
(continued)
sorry about this.....
I don't see anything suspecious and I'm looking for a hint as to where the problem is.
Can anybody suggest how to do that?
Rafi
(4,146 Views)
Hi Rafi,
When do you see this error? Do you see it when compiling, building a dll, calling from TestStand, or something else?  Are there any circumstances under which the program will run? Any more detailed information you can give will be helpful.  Thanks!
NickB
Applications Engineering
(4,119 Views)
Thanks Nick,
I found the source for the trouble.  There was a mismatch in parameters types between the code (CVI) and TestStand.
I still would like to ask....if there's a buffer in CVI (12K bytes), and I want to transfer it to TestStand as a parameter.  Shall I define in TS a c-type buffer buf1[12000], or shall I use a pointer  *buf.  Taking the first choice solved the problem but I wonder if this is the way to go....(TS parameters like ReportText are transfered like this....).
Rafi
(4,099 Views)
Rafi,
Yes, the first method you mentioned is the best way to pass a string/buffer as a parameter to TestStand.
NickB
(4,029 Views)
