LabWindows/CVI
NIReport_Print LabWindows 2009 vs 2010
I have code complied under LabWindows 2009 that is working, but when I complie it under LabWindows 2010 it stops working.
I am trying to create pdfs using Adobe Distiller, functions like PrintPanel and PrintTextBuffer work in both 2009 and 2010.  However,
NIReport_Print only works in 2009, if I try to print to Adobe.  It works printing to a real printer.
I have attached the code the works and doesn't work.
/* print report to the default real printer - THIS WORKS */
  if(!iLocalFail)
   iLocalFail = Report_ErrorHandler(NIReport_Print(iReportHandle, NULL, 1), "Report Print");
/* set printer to adobe pdf to create pdfs */
  iLocalFail = SetPrintAttribute(ATTR_PRINTER_NAME, "Adobe PDF");
  if(iLocalFail < 0)
   printf("SetPrintAttribute was %d\n%s\n", iLocalFail, GetUILErrorString(iLocalFail));
/* create the key for the buffer test */
  if(!iLocalFail)
     sprintf(caFilenameWithPathInfo, "%sBuffer_%s.pdf", TEST_DIRECTORY, caMyTime);
    iLocalFail = RegWriteString(REGKEY_HKCU, ADOBE_KEY, ADOBE_NAME, (unsigned char * ) caFilenameWithPathInfo);
    if(iLocalFail < 0)
      sprintf(caMessage, "RegWriteString Failed.\n, Error was %d.\n%s\n", iLocalFail, GetGeneralErrorString(iLocalFail));
      MessagePopup("RegWriteString", caMessage);
      iLocalFail = TRUE;
    else
     printf("Printing Buffer\n");
/*THIS WORKS */
/* read a dummy file to get data into a buffer and then print to the adobe printer */
  iFileHandle = OpenFile("c:\\mfgtests\\pdf_tester\\globals.h", VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII);
  if(iFileHandle > 0)
    ReadFile(iFileHandle, caBuffer, 50000);
    PrintTextBuffer(caBuffer, "");     /* "" for printer becasue of SetPrintAttribute */
/* create the key for the panel test */
  if(!iLocalFail)
    sprintf(caFilenameWithPathInfo, "%sPanel_%s.pdf", TEST_DIRECTORY, caMyTime);
    if(iLocalFail < 0)
      iLocalFail = TRUE;
    else
     printf("Printing %s\n", caFilenameWithPathInfo);
/* THIS WORKS */
/* print the panel, NULL for printer because of SetPrintAttribute */
  iLocalFail = PrintPanel(ghMainPanel, NULL, 1, VAL_FULL_PANEL, 0);
  if(iLocalFail < 0)
    sprintf(caMessage, "Error was %d.\n%s\n", iLocalFail, GetUILErrorString(iLocalFail));
    MessagePopup("Print Panel Failed", caMessage);
/* create the key for the report test */
  if(!iLocalFail)
    sprintf(caFilenameWithPathInfo, "%sReport_%s.pdf", TEST_DIRECTORY, caMyTime);
    if(iLocalFail < 0)
      iLocalFail = TRUE;
    else
     printf("Report Handle %d Printing %s\n", iReportHandle, caFilenameWithPathInfo);
/* THIS DOESN'T WORK */
/* print the report, NULL for printer because of SetPrintAttribute */
  if(!iLocalFail)
  printf("Done\n");
  NIReport_Discard(iReportHandle);
(3,814 Views)
Hi Paul,
Are you receiving any specific errors? Could you post a screen shot of it if you are getting one? That would help us understand what is happening a little better. Thanks.
Perry S.
(3,795 Views)
There is no error message from either the code or the print queue.  Watching the print queue, the file flashes in the queue.
(3,784 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
It seems like NI_ReportPrint is the only function that has a problem with creating pdfs.  WordRpt_Print, PrintTextBuffer, PrintPanel and PrintTextFile all automatically create PDFs using the Abode SDK.  So I am going to use WordRpt and not NI_Report from now on.
So if you need PDFs created, don't use NI_Report.
(3,763 Views)
