LabWindows/CVI
NIReport_ConvertCVITable
I'm having a problem with the NIReport_ConvertCVITable. I have a table with 8 columns and the following widths
47, 60, 60, 55, 85, 55, 85 50 when I send it to the printer all I get is blank header and 5 lines that run the entire width
of the paper which is in landscape. I have used the same routine to printout different tables with varying number of
columns and widths and most of they work. Any help would be appreciated!!!!!!!!!!!!!!!!
(3,212 Views)
Hi cjp1,
Is it possible for you to post example code that generates the behavior you are seeing?
Milan
(3,201 Views)
Thanks for your reply.  But I have found the problem. I had a set a right and left 0.2 inch margin and once I removed them if worked fine. I need to print out about 35 different table configurations and the 0.2 inch margins worked with about 30 of them.
(3,189 Views)
