LabWindows/CVI
NIO-DAQmx physical channel on easytabs
   I am a new user of LabWindows CVI 9.0. I am having a problem with easy tabs and loading channels on each tab. I get the from the DAQ on the first easy tab but am unable to get them on the rest.
I load the pannel and then convert from canvas to load the tabs. I have four tabs with names CH_1, CH_2, CH_3, CH_4.
Then I use
NIDAQmx_NewPhysChanAOCtrl(tabCtrl, CH_1_PHYS_1, 0);         where PHYS_1 is a constant on the first tab
when I use
NIDAQmx_NewPhysChanAOCtrl(tabCtrl, CH_2_PHYS_2, 0);
NIDAQmx_NewPhysChanAOCtrl(tabCtrl, CH_3_PHYS_3, 0);
NIDAQmx_NewPhysChanAOCtrl(tabCtrl, CH_4_PHYS_4, 0);
it does not compile but gives an unknown error. My DAQ has four channels. Please help me and tell me what is the prob?
Farhan Ahmad.
(3,823 Views)
Accepted by topic author lahorimunda
Hi lahorimunda,
the most common cause for problems on tab controls or easytab controls is the use of an incorrect panel handle: NIDAQmx_NewPhysChanAOCtrl takes a panel handle as the first parameters, while you are passing "tabCtrl" which seems to me is a control ID. I may be incorrect, but I would check this item first.
Now, for easytab controls, when you add panels to the tab control with EasyTab_LoadPanels you get back the panel handles, while if you are using EasyTab_AddPanels you already have obtained the handles; are those handles that must be passed to every function that must address a control on a tab page.
The same applies if you want to use native tab controls available in CVI9 instead of the EasyTab: you prepare the tab pages at design time and obtain the panel handles at run time with GetPanelHandleFromTabPage.
(3,817 Views)
Hi Roberto,
                 Thanks a lot for your help. I needed to load panel handles for each tab which I did and now it works fine. tabctrl was a general panel handle I guess. Anyways thanks a lot.
Farhan Ahmad.
(3,804 Views)
