LabWindows/CVI
NI Runtime Installation - Windows Installer Error
Dear NI Support team and Members of the Forum,
I currently have a problem installing our software on a customers
computer. I have found a more or less equal error in your Discussion
Forum describing it.
If I want to install our software (Build with LabWindows/CVI 8.5), on
Installationstartup I get an error that I am in Safemode or don't have
administrative Rights to
proceed the installation by the Windows Installer. I did an update on
Win Installer 4.5 (v3), tried to reregister and to reinstall the
Windows Installer but it didn't solve our Problem.
The same problem occurs also if I try to install the NI Runtime Engine
(I attached also two installation logs for you).
I saw the problem (regarding
http://digital.ni.com/public.nsf/allkb/89073CCF16C0AE5986257715008113E8
) could come by one or two hotfixes, but they aren't installed on the
system, would the third Hotfix still be a possible solution?
with friendly regards,
Thomas Mailänder
(3,233 Views)
here is a Microsoft KB related to the error message you are getting, which is generally connected to a corruption of msiexec.exe .
Try to follow the described procedure.
I hope this helps!
Bye!
Licia
(3,213 Views)
