LabWindows/CVI
NI-DAQ LabWindows support
For some reason the NI-DAQmx installer refuses to install LabWindows support. It says it only works with LabWindows 7 and above... I'm using LabWindows 2013 (version 12).  In fact, the installer won't let me select anything.
I need to get LabWindows support installed. Any ideas?
FYI: I have Measurement Studio installed also. Windows 7 64bit. My applications are compiled to 32bit though.
(5,470 Views)
I believe the reason that you are running into this issue is that DAQmx 9.6.2 is not compatible with LabWindows/CVI 2013.  The following is included on the DAQmx 9.6.2 download page:
I would recommend installing DAQmx 9.8, which is compatible with LabWindows/CVI 2013, and can be found on our website here:
http://www.ni.com/download/ni-daqmx-9.8/4297/en/
(5,431 Views)
Hello WayneS1324,
This configuration should be working. After some investigation over here, we were able to install NI-DAQmx 9.6.2 support with LabWindows/CVI 2013 installed. Have you tried installing NI-DAQmx 9.6.2 by itself? You can find the download page here: NI-DAQmx 9.6.2.
Let me know if the standalone installer still does not allow you to select LabWindows/CVI Support.
Daniel
Daniel Dorroh
(5,347 Views)
