LabWindows/CVI
Multiple text string display in one for/while loop
I have around 700 text string displays in different tabs in my application which displays some angle values. I am using SetCtrlVal function to display the buffer contents. The problem is, I have 700 displays and I have to use 700 SetCtrlVal functiions to display them. Is any smart way to use one SetCtrlVal function in a while loop with variable constant names for text displays in the function parameter.
thanks,
Sandeep
(3,630 Views)
If you are using CVI2010 you can benefit from the control arrays facility.
Alternatively, you could create a list of control IDs and use it in a loop:
int   ctrls[10];
ctrls[0] = PANEL_CONTROL01;
ctrls[1] = PANEL_CONTROL02;
ctrls[9] = PANEL_CONTROL10;
for (i = 0; i < 10; i++) {
   sprintf (msg, "%.1f", angle[i]);
   SetCtrlVal (panelHandle, ctrls[i], stringArray[i]);
The alternative of using SetAttributeForCtrl or SetAttributeForList is not feasible in your case since you are using strings: these commands are powerful but can treat only integer values.
(3,563 Views)
Thanks Roberto. That should help.
One more question. I have some logic running which will tell me if the angle value is within a limit say +/- y. I want to color the text with red if the angle is out of limit else will be black. So I will have to use SetCtrlAttribute to change the text color. My question is that whether can I use this function same as SetCtrlVal you mentioned above?
Sandeep
(3,559 Views)
Yes, you can. You may have problems if the panel your controls are on is set as "Conform to system colors": in this case the code won't honour SetCtrlAttribute statement but will return no error.
(3,556 Views)
Thank you Roberto, I have disabled the "Conform to system colors" and works well. Thanks for the tip.
(3,553 Views)
