LabWindows/CVI
Multiple protocol interface (help)
In some commecial TV there is a "Multiple Protocol Interface (MPI)
QuickSet Programming" function. Do someone know more detail about MPI?
Thanks!
(3,691 Views)
I did some searching about this on Google, and it seems that it is a protocol that some LAN cards (and motherboards) support that understands any protocol you send to it (UDP, TCP/IP, TelNet, etc) and sends these to a higher level protocol that knows how to understand them. That's the most information I could find on it, but you may have better luck posting in another online forum about this.
Brandon Vasquez
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(3,666 Views)
