LabWindows/CVI
Multiple analog output task
Thank you very much. It was a great help. 🙂
Message 11 of 13
(1,824 Views)
You're welcome! Smiley Happy
It would be great if you can mark the most relevant answer as solution to better help future readers of this thread.
Message 12 of 13
(1,814 Views)
just a simple example to generate a sinus on 2 output channels:
    DAQmxCreateTask("",&taskHandleCH1_2);
    DAQmxCreateAOVoltageChan(taskHandleCH1_2,"Dev1/ao0:1","",-10.0,10.0,DAQmx_Val_Volts,NULL);
    DAQmxCfgSampClkTiming (taskHandleCH1_2, "",Frequency * Samples, DAQmx_Val_Rising, DAQmx_Val_ContSamps, Samples);
    //Sinus on channel1
    SineWave (Samples, Amplitude , 1.0/ (double)Samples, &Phase, Sinus);
    //Sinus on channel2
    SineWave (Samples, Amplitude , 1.0/ (double)Samples, &Phase, Sinus+Samples);
    // DAQmx Write Code
    // Channel 1 and 2
    DAQmxWriteAnalogF64 (taskHandleCH1_2, Samples, 0, 10.0, DAQmx_Val_GroupByChannel,
                         Sinus, NULL, NULL);
    // DAQmx Start Code
    DAQmxStartTask(taskHandleCH1_2);
I just test this with ni pxi4461 and it works fine.
Message 13 of 13
(1,809 Views)
