LabWindows/CVI
Modality using different threads
The main panel has a list box, where elements are added from a thread invoked on OK button.For a particular condition I need to pop up a panel from the thread.My execution of the thread should stop and wait for a return from the popped up panel and then continue.While i am not able to get any control of the popped up panel and also the process continues to perform not waiting for a return. How do i program this application ?
with gratitude
vivek
(3,510 Views)
You can call InstallPopup() to display the panel, GetUserEvent() to wait for the panel, and RemovePopup(0) to remove it.
InstallPopup doesn't cause your code to wait: it just installs and displays a modal dialog box. GetUserEvent with Wait Mode set to wait will wait until an EVENT_COMMIT is generated. GetUserEvent then returns the panel and control that generated the EVENT_COMMIT.
See answers to previous questions here [broken link removed]
(3,510 Views)
Hello ,
Thank you very much for your help.
I have been able to solve my problem using
GetUserEvent()
regards
vivek $
(3,510 Views)
