LabWindows/CVI
Missing prototype function
I am using Labwindows/CVI 5.5. The code works with Visual c++ but it does not work here.
My code:
typedef struct testfunc
int para;
int (*stepfunc)();
}TESTFUNC;
int EXE_test(TESTFUNC *pfn)
int result;
if(pfn->para==VOID)
result=(*pfn->stepfunc)();
else result=(*pfn->stepfunc)(pfn->para);
Compiler of CVI says missing protype function at (*pfn->stepfunc).
Please, help.
(3,204 Views)
Hi I'm not sure but I thing you need to replace
int (*stepfunc)(); with
int (*stepfunc)(void);
I did encounter sommething similar... when library build with VC++ you don't need to put "void" in the function declaration when there is non parameters... but in CVI we need to...
I hope it is the right answer...
Best Regards
Steph
(3,204 Views)
