LabWindows/CVI
Missing Prototype Error (LabWindows/CVI)
I developed an application 3 or 4 years ago with Labwindows/CVI 5.5 ( I do not remember what version of Nidaq I had at the time).
I have Labwindows/CVI 6.0 now and Nidaq 6.92. When I try to compile my old application I get the following errors:
Missing Prototype
This is for the following function:
nidaqAIScanOp (Channel, iNumData, dSampleRate, dMax,dMin, kNidaqGroupByChannel, &dScanRateActual, dValues);
And I also get this error:
Undeclared identifier 'kNidaqGroupByChannel'.
Does anyone know what steps I should take? I have several similar errors like this for other nidaq data acquisition functions. Thanks for the help.
(4,520 Views)
That line of code looks okay, the nidaqAIScanOp function is in the Easy I/O For DAQ Library. Make sure that you have the DAQ support for CVI installed if you can't find it.
Ryan K.
NI
(4,520 Views)
Ryan,
When I use the Easy I/O for DAQ library there is a different function. It used to be nidaqAIScanOp, but now it is:
AISampleChannel (Device, channel, Max,Min, Sample);
This is what I'm talking about. It does the exact same thing, but has a different name. Do you think that it depends on what version of Nidaq is installed? What version do you have?
Scott
(4,520 Views)
Ryan,
Sorry the equivalent function call is:
AIAcquireWaveforms(device,channel,num_samples,sample_rate, max, min,actualscanrate ,GROUP_BY_CHANNEL, waveform);
The function from the previous comment replaced:
nidaqAISinglePointOp(Channel, CHANNEL_MAX,CHANNEL_MIN, &value);
This causes major headaches when I'm trying to do some simple updates.
Scott
(4,520 Views)
Scott,
The functions that you list (AIAcquireWaveforms, AISampleChannel) are present in my version of CVI, but are grouped under the "obsolete" section of the Easy I/O library. The functions you were originally using (the ones starting with nidaq)are found under Easy I/O->Analog Input->Easy Analog Input. Try pressing ctrl-shift-p and then typing in the name. I am running CVI 7 and DAQ 7.1. If the functions aren't showing up you might try updating your DAQ install.
Hope that helps,
Ryan
(4,520 Views)
