LabWindows/CVI
Memory leak in FFT function
Hi everybody
I have a memory leakage when using the FFT() funtion in the Advanced Analysis library. I have evn tried the example code given by NI:
double x[256], y[256];
int n = 256;
unsigned int UsedBlocks, UsedBytes;
Uniform (n, 17, x);
Uniform (n, 17, y);
CVIDynamicMemoryInfo ("", &UsedBlocks, &UsedBytes, DYNAMIC_MEMORY_SHOW_ALLOCATED_MEMORY_SUMMARY);
FFT (x, y, n);
The UsedBlocs and UsedBytes is increased after the call to FFT. Any ideas?
Thanks in advance
-burobengen
(4,291 Views)
I have reproduced this as well. I'll file a bug report for this.
In the meantime, try using ReFFT if you need to perform an FFT on a signal. Or if you have CVI FDS, use the AmpPhaseSpectrum() function if all you want is the amplitude and phase of the signal. They seem to be working correctly.
Bilal Durrani
NI
(4,277 Views)
I have version 7.1.1 and it still has this bug (memory leak in FFT function).  Is there any way to fix this?
DS
(4,099 Views)
Actually, I am pretty sure the FFT function does not actually leak memory.  The bug is that memory is noted as leaked from the memory info functions.
(4,097 Views)
The FFT memory leak was confirmed to be fixed in CVI 8.0.
Bilal Durrani
NI
(4,079 Views)
