LabWindows/CVI
MediaBuilder Return Code 519?
I am getting a 519 error code when I try to create a distribution kit. What's it mean?
(3,411 Views)
This error isn't listed in our Knowledgebase. It could be lots of things. I would advise having one of our engineers help you with it. You can send the project to our engineers via http://www.ni.com/ask.
Also, you seem to be using CVI 5.5 or previous. The latest version of CVI (version 6.0) has a brand new distribution kit tool that uses Microsoft's MSI installer. It is a much improved distribution packager.
Best Regards,
Chris Matthews
(3,411 Views)
Chris, yes. I am running version 5.5. I want to evaluate the support I get from this issue before investing another couple of thousand dollars in a new version. My last issue with the inet toolkit, which you recommended that I contact a support engineer is still unresolved weeks later.
(3,411 Views)
This issue should be reproducible by our engineers so it shouldn't take long to track down. Also, upgrades are only $395, not a couple thousand.
Best Regards,
Chris Matthews
(3,411 Views)
i have just started getting this problem it has happened on all of out PC's coinstantally this has occured after out IT department installed an epo agend and new anti virus software. current thoughts is that we need to exclude some more directories form the anti virus software. Will keep you informed
(3,411 Views)
