LabWindows/CVI
Mathematical Expression Evaluator [Parser]
Is there some way in which a user enters some text in the string box
at the user interface, so that LabWindows/CVI evaluates this string?
For example, the user enters the text "(a+b*200)/63" as a string at
the user interface, so that the result of this expression is stored in
some variable.
I understand this involves parsing, but I am not too proficient at it.
If anyone can help me out in this, I would really appreciate it.
Thanks and regards,
Arvind Prasad.
Message 1 of 9
(4,074 Views)
"Arvind" wrote in message
news:d0d35dd7.0403021500.64bd569f@posting.google.com...
> Hi,
> some variable.
This simple goal may take longer that what most might expect. I refer you to
a topic "4.3 External Variables" on page 73 from the K & R, second edition.
The topic gives code for a calculator using reverse polish nota
tion.
Mohan Pawar
> Thanks and regards,
> Arvind Prasad.
Message 2 of 9
(4,074 Views)
The attached code allows evaluation of expressions in X, Y and T. You first supply the expression as a string to Convert(), then you can use Evaluate() to calculate the results for given X,Y,T values.
HTH,
Martin.
Martin
Certified CVI Developer
Message 3 of 9
(4,074 Views)
In message , Arvind
writes
>Hi,
>some variable.
>Thanks and regards,
>Arvind Prasad.
You should be able to find quite a number of algorithms written in C at
this site www.programmersheaven.com
You'll have to adapt them to work with CVI but it shouldn't bee too
hard.
Reg
ards,
John Cameron.
Type softly, read gently.
Message 4 of 9
(4,074 Views)
Hi Arvind,
I have no ideas what are labwindows and cvi but you can try Cioina.dll from
http://www.geocities.com/alexei_cioina/cioinaeval.html
Best regards.
Alexei.
arvind@cae.wisc.edu (Arvind) wrote in message news:...
> Hi,
> some variable.
> Thanks and regards,
> Arvind Prasad.
Message 5 of 9
(4,074 Views)
Hi Mohan,
Thanks for the reply. I will surely look through the article u have suggested.
Thanks for ur time,
Arvind.
Message 6 of 9
(4,074 Views)
Dear Martin,
Thanks for the code supplied! I will try and implement it into my application and will surely include a credit line for u!
TSH [That sure helped!]
Thanks for ur time,
Arvind.
Message 7 of 9
(4,074 Views)
Dear John,
That was an awesome link, I found "EXACTLY" what I wanted!
Thank you very much,
Arvind.
Message 8 of 9
(4,074 Views)
Dear Alexei,
Thanks for replying. I haven't yet tried out the dll since I might have fnd an alternative. But thanks for replying and I will get back to you if I use the dll.
Arvind.
Message 9 of 9
(4,074 Views)
