LabWindows/CVI
Math Functions for NI-Scope
I am just beginning to program a PXIe-5160 and don't see any math functions in NI-Scope.  I am used to a Tektronix or LeCroy scope where the math functions are built into the scope.
Do I have to write my own math functions like "Add" and "Difference"?
Paul
Message 1 of 9
(3,817 Views)
Wrong forum ?
Message 2 of 9
(3,737 Views)
I don't think so.  I am looking for LabWindows/CIV functions that would improve the  functionality of the NI-Scope.  I found a few in the Advance Analysis Library under the Signal Processing.   Maybe that is way NI want it, basic scope functions in NI-Digitizer, any more advance in the Analysis Library.
Message 3 of 9
(3,731 Views)
Message 4 of 9
(3,704 Views)
Trent,
Yes, these would do it.  However, NISCOPE_VAL_SUBTRACT_CHANNELS and NISCOPE_VAL_ADD_CHANNELS come back with an Error: 0xBFFA000C Attribute ID not recognized.  When I search for them in the Select Attribute Constant using the filter they do not show up.
Message 5 of 9
(3,674 Views)
I'm not sure what you're referring to - posting a code snippet or screenshot might help.
The Advanced Measurement Library Example might be a good starting place:
Help > Find Examples > Hardware I/O > Modular Instruments > NI Scope > Measurements
https://www.linkedin.com/in/trentweaver
Message 6 of 9
(3,669 Views)
The attribute NISCOPE_ATTR_MEAS_OTHER_CHANNEL is set using the niScope_SetAttributeVIString.  The attribute NISCOPE_VAL_ADD_CHANNELS is set using niScope_AddWaveformProcessing.  I was looking it the SetAttribute function.
Do you know if there is an order to which is ran firsst?  I am not seeing any difference in the fetched waveform.
Message 7 of 9
(3,662 Views)
To gdargaud's point, Someone on the High Speed Digitizers board might have some more specialized knowledge:
https://forums.ni.com/t5/High-Speed-Digitizers/bd-p/150
I'll share my 2cents anyway but I wouldn't call myself a SCOPE expert... When you call call commit(), or call some other method like initiate() that calls commit()), that's when the task settings actually get applied. In my experience, the exact order of configuration before that isn't important... the order of when you set them relative to committing is important
Hope this helps!
Trent
Message 8 of 9
(3,656 Views)
I am able to add and subtract the waveforms.  The problem I have is that the normal scope functions like niScope_ReadMeasurement and  niScope_FetchMeasuresmentStats do not work on the resulting math waveform.  So there is no easy way to get the Frequency of the math waveform.
Message 9 of 9
(3,647 Views)
