LabWindows/CVI
Making system() call from CVI
I'm trying to call system() from stdlib under CVI and retreive the resulting stdout/stderr messages. I can't seem to get anything but a non-zero output from system() and can't redirect stdout/stderr to a file. Are there any examples for doing this?
(3,395 Views)
If the application launched by the system command return a value on exit, you will catch that value and that value allone.
You can spool a command output to a file using a ">" redirect. i.e. cathing you IP info in a file you can do this:
ipconfig >ipinfo.txt
The you can read the file "ipinfo.txt" and the file will be generated in the same directory where the app was launched from or in the root of c: To make sure it's in the same place consistantly you can use SetDir (utility library) to set the current active directory.
There might be a better more elegant SDK function that will do what you are trying to do with a commandline application.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,395 Views)
