LabWindows/CVI
MS installer version issue
This isn't a problem with MSI engine 3.1 vs 4.5, as it's fully backwards compatible. If this problem is seen on Windows XP -- the most likely cause is that a particular buggy Microsoft hotfix is installed. Unfortunately, Microsoft has not published an updated fix that resolves this issue on XP (due to its ending support status), so the recommended workaround is to uninstall the bad hotfix before running the install (see the above KB for details).
Best Regards,
- Wes
Message 11 of 16
(1,327 Views)
If anyone has had success solving this problem by removing a hotfix or has ever had a correct install under Windows XP with Windows Installer 4.5 could you let us know?
Many thanks,
Ed
Message 12 of 16
(1,315 Views)
I just spent three days struggling with this problem, trying to load a toolkit for an older version of LV (8.6.1) on an old system so I could do some repairs on legacy code. No success using all of the standard installer fixes (unregister/register, shut off startup services, manually update Windows MSI dlls, etc.). I finally got to the point where I had IT set me up with a brand new PC that had a fresh install of XP SP3 and nothing else so I could do a clean, initial install of LV. Still the problem persisted. I uninstalled Hotfix 981669 using the "Add/Remove Programs" in Control Panel and the problem went away. I've since installed LV 8.6.1 and NI-GPIB with no issues at all.
Hope this helps.
Message 13 of 16
(1,284 Views)
Thanks for the response.  Does the Windows XP system in question have the v4.5 installer?  This is easily verified by typing
'MSIexec' at the command prompt.
Ed
Message 14 of 16
(1,273 Views)
It does - Version 4.5.6001.22159
You may also wish to check out this link: http://stackoverflow.com/questions/4332926/wix-error-windows-installer-hot-fix-981669
I found that information useful as I worked through this whole "adventure" 😉
Message 15 of 16
(1,262 Views)
Many thanks again.
Ed
Message 16 of 16
(1,250 Views)
