LabWindows/CVI
MS ActiveX TreeView Control with CVI 6.0
Has anybody experience with the new CVI 6.0 and the usage of the (Microsoft Windows Common Control)TreeView ActiveX Control? Help with a small demo a welcome.
(3,384 Views)
There is a shippingg example that uses it under \cvi\samples\apps\fpeditor\fpeditor.prj. It's a pretty big example that shows how to generate FP's programmatically, but it does demonstrate the use of a Microsoft TreeView.
Best Regards,
Chris Matthews
(3,384 Views)
Jens
Here is a small program that loads a treeview control. This example doesn't load any nodes in it.
I hope this helps you get started.
Brian
(3,384 Views)
