LabWindows/CVI
Looking for LabWindows CVI Drivers for Netcom Systems Smartbits
Could anyone please point me to where or whom has a LabWindows CVI Driver for Netcom System's Smartbits. I did notice that the drivers for LabView were written, but have not found for CVI.
(3,660 Views)
When you load NETCOM, you should have the following path created: c:\Program Files\Netcom Systems\SmartLib\CommLib which should have a file called smbw32bc.lib in it. Include it in your project and it should have all the drivers you need in it. We've been using this file for many years now.
(3,660 Views)
I am having a problem trying to get this to work. DO you have a typo in the file name? I have the file smbw32vc.lib. My project will not run. It has a problem with the definition of a 64 bit integer. I know that it works with CVI 7.0 bit I would like to get it to work with version 6.0.
The error occurs in the file ettypes.h. The file contains the following:
#if defined WIN32
#define int64 __int64
#define uint64 unsigned __int64
#endif
#ifndef int64
#define int64 long long
#define uint64 unsigned long long
#endif
typedef union tagINT64_T {
struct {
unsigned long low;
long high;
} i64;
int64 int64_t; /* error HERE found id expected } */
} INT64_T;
Any help would be great.
(3,660 Views)
