LabWindows/CVI
List Box Row Highlighting
I would like to keep the active selected row of a list box fully highlighted even when the list box is not the current active control.  How can this be done?
(3,645 Views)
AFAIK a listbox does not maintain highlighting when it's not the active control. Instead, a dotted box surrounds the active item when not active.
A possible solution to this could be to trap EVENT_GOT_FOCUS and EVENT_LOST_FOCUS in the listbox callback: when loosing focus get the active item and replace it with the same text adding a proper combination of backgroun / foreground colors, when getting focus, replace again it with the normal black/white colors. The background color will encompass only the printed text: if you want to highlight the whole line you'll need to add extra spaces to item text. For help on using colors in a listbox look at \samples\userint\listdelx example.
(3,634 Views)
Thanks!.  Your suggestion along with the addition of a few other housekeeping details works, except for the first time that I leave the list box and focus on a different control.  In this only first only instance I never trap on the EVENT_LOST_FOCUS event.  At all subsequent times that I go back to the list box I get a the appropriate EVENT_LOST_FOCUS and EVENT_GOT_FOCUS events.  But aside from this one minor issue, the method works nicely.
(3,601 Views)
