LabWindows/CVI
Linux/CVI : which packages for embedded pc ?
I have installed CVI for Linux on my labtop in order to be abble to developpe software for small embedded pc.
As these small embedded pc use no hard disk but a smaller compact flash memory, I have to minimise the number of data written on the memory.
So, if a "standard" software with no specific driver (ex : serial.prj) is fully created on my labtop using the same Linux kernel (Aurox based on Redhat),
- is it enough to have nicvirte-8.0.6.i396.rpm installed on a computer if no software is created on that pc (only running) ?
On installing all the packages on my labtop, i have been required to install kernel dev. package.
Can you precise all the dependance ?
Normaly the system on the embedded pc will have only a kernel file, a small root files system and Xwindows if nothing else is required.
(2,979 Views)
Hello Mbuton,
Please check the ReadMe file to know which distributions are supported.
___________________________________________________________
The LabWindows/CVI Run-Time Module for Linux software for the Intel x86 32-bit
architecture supports the following distributions:
Red Hat Enterprise Linux WS 3
Red Hat Enterprise Linux WS 4
SUSE Linux 10.0
SUSE Linux 10.1
Mandrakelinux 10.1 Official
Mandriva Linux 2006
________________________________________________________________________
Aurox is based on RedHat/Fedora and so not supported.
Regard,
(2,951 Views)
