LabWindows/CVI
Link error - prototype not found: SetEasyIOMultitaskingMode()
I cannot compile my application. I receive the following link error:
Prototype not found: SetEasyIOMultitaskingMode ()
How, or where, do I get the file that has the prototype for this function?
Dan
(3,360 Views)
That function is part of our Easy I/O library for DAQ. That library installs with the NI-DAQ software. It sounds like you need to reinstall NI-DAQ and install CVI support to update that library. If you already have NI-DAQ installed, go to Start->Programs->National Instruments->NI-DAQ->NI-DAQ Setup. Go through the setup process and make sure LabWindows/CVI support is installed and that it is installing to the correct directory (your cvi main directory.
Best Regards,
Chris Matthews
(3,360 Views)
Chris,
Thanks for the reply, but it did not work. I had previously installed 6.8.1 I re-installed the 6.9.2 driver from the CD-ROM and rebooted, but I still get the same link error (Undefined symbol: SetEasyIOMultitaskingMode).
I'll give you more info:
I am modifying an application that runs on a PC (running Windows2000) which tests a separate Linux machine. Someone in my team is running NT and can compile it without problem. I included a Word doc with a picture that shows what I have selected when installing from the NiDAQ CD-ROM. I think the correct file is easio.h and I have searched my whole hard drive but cannot find it.
Measurement Studio is installed in C:\Measurement Studio and my application is in a separate directory (C:\work_
projects). I wouldn't expect that to be a problem.
Any help is appreciated,
Dan
(3,360 Views)
That should have installed the files. I'm not sure why it isn't. You should give our support engineers a call and let them try and fix it or if they can't they can e-mail you the files. To generate a service request and call us go to http://www.ni.com/ask.
Chris
(3,360 Views)
