LabWindows/CVI
Library errors
My code returs Library function error (return value == -38) - the id passed must be a menu id or menu item id.
Using CVI 8.5 full feature OI. This occurs in RebuildEditMenu() function on the call TS_CleanupMenu().
If I comment out the TS_CleanupMenu() call then it return menu id error -13 - Invalid control ID on RunUserInterface() function.
I do have another cvi code that launched the custom UUT dialog box and this error is reported every time a particular button of the dialog is clicked.
static int RebuildEditMenu()
int error = 0;
CAObjHandle viewMgr = 0;
int menuBar;
menuBar = GetPanelMenuBar(gMainWindow.panel);
// determine which view manager the menu commands apply to
errChk( GetActiveViewManager(&viewMgr));
// discard any current menu items that were inserted by TS_InsertCommandsInMenu
errChk( TS_RemoveMenuCommands(menuBar, BAR_EDIT, FALSE, FALSE));
// rebuild Edit menu
errChk( TS_InsertCommandsInMenu(sEditMenuCommands, menuBar, BAR_EDIT, -1, viewMgr, NULL, TRUE, errMsg));
// remove duplicate separators and shortcut keys
errChk( TS_CleanupMenu(menuBar, 0)); //jjt
Error:
return error;
Any advice as to what is causing the error.
TIA
(3,061 Views)
Hi sonotk,
Would it be possible to post a screenshot of the errors you're seeing, specifically the first error (the library function error)?
Thanks!
(3,046 Views)
