LabWindows/CVI
Less than symbol problems
Hello everybody,
ich have written a code, nothing special.
    if(Phi < 0.25)
        A = 1;
Now I have a problem. When I get a value Phi = 0.25, Lab Windows jumps into the bracket and writes A=1.
But that is not correct. 0.25 is not smaller, it is equal. Is this a failure of the program or have I forgotten something?
Best Regards
(5,739 Views)
yes, you have forgotten something called numeric precision, see, e.g., here Smiley Wink
(5,736 Views)
Ok thank you. But how can I solve the problem? I tried the solution in the othee topic but it didn't work.
(5,657 Views)
Can you provide some more information about your input data such as the resolution of your measurement? How did you check the value of your number / with which CVI version (note that more recent versions have some limitations in debugging due to automatic rounding, see here)
(5,646 Views)
This is a part of a calucation. I have a signal and that signal has a length from 1. And from 0-0.25 the signal has a positive Amplitude, so therefore I need to give aut a 1 and from 0.5 to 0.75 I have a negative ampltude, so I give out a -1. I get the comparitve value from another calucation as a double value.
When I transformed the double value into a int
double Phi = 0.25 * 1000.0 ;
int a = Phi;  // 249
I got a int with the value 249. So the value got rounded. So this was not a option.
I used printf to show me the value. The first values are exactly the same 0.25 = 0.25, 0.5 = 0.5,... but after some time the value got this behavior 0.25 = 0.249500998 seen in the following.
I use the CVI Version 2015
(5,641 Views)
Maybe this is not the answer you wanted to hear but...
- I would conclude that the main problem is not your initial comparison statement but some accumulating inaccuracies in your calculation, probably due to cumulative roundoff errors... but this is a common issue, when reading some books about numerical recipes you will find that for this reason many routines claim only 7 or 8 valid digits, even if done with double precision
- there is no simple answer. The usual approach for comparisons is sketched here (I had a more detailed link but can't find it right now, sorry)
(5,627 Views)
thank you anyway. I thought so that there is a basic failure and I think it is really the calculation.
Best regards
(5,618 Views)
