LabWindows/CVI
Left() function location in CVI library
Trying to use  function >> Left(string, NumberofCharacters) that is available in TestStand in a CVI file. Cannot find which CVI library this is located in.  Above functions returns substring of argument string of length NumberofCharaters.
(3,527 Views)
You can use strncpy (tgtString, srcString, NumberOfCharacters);
Please read carefully the online help for the function to understand its behaviour in the various cases: it is normally enough to add
tgtString[NumberOfCharacters] = 0; to ensure that the string is null-terminated, but you must be aware of strncoy behaviour with different lenght strings.
(3,521 Views)
I have never come accross the left function in CVI. However, I believe the function StringCopyMax found in Programmers Toolbox>>String Handeling does the same function that you are looking for.
Jack J.
(3,496 Views)
