LabWindows/CVI
Launching a function from a DLL on first access
Hi All,
I would like to create a generic SW that can retrieve data from different DLL files. To do this I would like each of these DLL files to execute a single, pre-defined function when the SW accesses it for the first time (the SW will go over a directory with the DLL files to be used).
My problem is that I don’t want to change my SW each time I add a new DLL (declare the DLL function name to be executed on startup, etc.). I thought of using the DLL Attach mechanism but this will execute every time a function from the DLL will be called and not only once.
Do you know of any DLL properties that may help me do this?
Gil
(3,513 Views)
The PROCESS_ATTACH in DllMain occurs the first time you load the dll into a process. So unless you are explicitly loading and unloading the dll in your SW everytime you call a function in the dll, you will get this event only once.
Or what you could do is always load a function with a specific signature and then make this a required condition for all dlls that your software uses. You basically recommend who ever is creating the dll to alwasy have a particular startup function defined. So kinda like agreeing on an interface for the dll to work with your app
Hope this helps
Bilal Durrani
NI
(3,506 Views)
Hi Bilal,
I have managed to achieve my goal by loading the *.lib file(s) using LoadExternalModule and executing a unique entry point function in each DLL by using RunExternalModule.
Thank you very much for help,
Gil
(3,464 Views)
Thats great.
If you don't want to have to distribute the DLL and the import library with your CVI application, you might also consider using LoadLibrary() and GetProcAddress() ( part of the Windows SDK ) to load the DLL directly and call the function from it. Check out this KB here for more info.
Hope this helps
Bilal Durrani
NI
(3,442 Views)
