LabWindows/CVI
Labwindows - the system cannot find the specified file
Trying to rebuild a project that has not been changed for a couple years, last built with older verision of labwindows.  The build completes fine with version 20.0.0 labwindows.  But when I try to run the installer I get "the system cannot find the specified file"
It does not show what the missing file is.
I can install older builds with no issue, so I do not think it is the computer or antivirus...
(1,697 Views)
Have you rebuilt the installer in cvi 2020 as well?
(1,665 Views)
Yes, rebuilt installer.
So this will only not install on a specific windows 10 computer. Other windows 10 computers the installer works.
I have attached a log file from the install, but I can't determine what the issue is, may be you can see it.
(1,655 Views)
As far as I can understand, the error is listed towards the end of the log file:
Error: Failed to access database: D:\Labwindows\O2ALERT\Rev 2.04\cvidistkit.o2alert\Volume\bin\dp\O2ALERT.msi
Looking at distribution kits I create for our products, it seems the installer cannot find the basic .msi file for your product: check the distribution folder and see if the file is present.
Are you trying to install from a local isk, a remote unit or a removable unit?
(1,649 Views)
Yes, file was there.  Not sure why it cant find it.  Even tried running setup as admin... no difference.
So, I copied the Volume folder (that has the entire install)  to my desktop.  then ran the setup file from the desktop and it worked.   Not sure why it worked,  I assume something in the directory structure.    Other computers on my network access the build folder as is, and it works fine?  At least it worked now!
Thanks!
(1,642 Views)
