LabWindows/CVI
LabWindows & call software
Is LabWindows can call software such as compessed software?
(3,277 Views)
I assume you really want to run and external program from your application.
The easiest way to do that is use the Utility library and pick the LaunchExecutables function or its extended version.
(3,255 Views)
I know two ways to launch an application. You can directly launch an executable, or you can use the ActiveX Controller Wizard to start and handle the applications.
Best Regards
(3,230 Views)
Thanks for your suggestion, I will try it !
(3,213 Views)
