LabWindows/CVI
LabWindows Multiple-file compile
who can tell me why i can not compile this simple *.pro successfully,  compiler hint is missing prototype(GPS_start_test())
the progam simplely list as follow:
GPS_main.c:
#include <userint.h>
#include <cvirte.h>
#include "GPS_test.h"
#include "GPS_main.h"
void update()
 MessagePopup("GRETAT", "hello")  ;
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
 update();
 GPS_start_test();
 return 0;
GPS_main.h:
#ifndef _GPS_MAIN_H
#define _GPS_MAIN_H
void update();
#endif
GPS_test.c:
 void GPS_start_test()
 MessagePopup("test","OK");
GPS_test.h:
#ifndef GPS_TEST_H
#define GPS_TEST_H
void GPS_start_test();
#endif
just so simple ,but i can not compile it successfully.
2)another question is who can tell me which function in CVI or Windows SDK can get system time in ms unit.
Thank you in advance
(3,462 Views)
1)function prototype without parameter must be func(void);
GPS_test.h:
#ifndef GPS_TEST_H
#define GPS_TEST_H
void GPS_start_test(void);
#endif
GPS_main.h:
void update(void);
2)SDK function to get system time in ms unit
GetLocalTime(SYSTEMTIME *ltime)
  ltime.wDay   ;
  ltime.wMonth ;
  ltime.wYear  ;
  ltime.wHour  ;
  ltime.wMinute;
  ltime.wSecond;
  ltime.wMilliseconds;
some other useful function SystemTimeToFileTime-FileTimeToSystemTime,GetTimeZoneInformation
(3,444 Views)
Thank you for your  help, according your reply  i have solved this problem
(3,419 Views)
