LabWindows/CVI
LabWindows Core 1 Course Section 4 Unable to find File
I just completed section 4 of the LabWindows Core 1 Course that goes over Distributing LabWindows/CVI applications and at the end it mentions:
 Open the <Exercises>\CVI Core 1\Lesson 4\cvidistkit.Tempsys\Volume folder and run setup.exe to install the Tempsys application.
 When you have completed the installation process, select Start»All Programs»Tempsys»Tempsys to run the program.
The problem is under the Volume folder there is not a setup.exe anywhere to be found. Does anyone know what may be the problem?
Message 1 of 1
(1,019 Views)
