LabWindows/CVI
LabWindows/CVI can not compile a simple code
Hi all!
It is looks funny but LabWindows/CVI-9.1.0(427) can not compile a simple C-code  :smileyvery-happy:
xml.h
void f();
xml.c
#include "xml.h"
typedef struct
    int bar;
} foo;
void f()
    int baz=0;
    if(!baz) baz=1;
    foo foop;
    return;
(3,794 Views)
Accepted by topic author kolan
It's not a bug, you're doing an in-block declaration of a variable foop which isn't allowed in ANSI C89.
You can enable C99 extensions with a pragma if you want this to work in CVI 9.1
Menchar
(3,791 Views)
Yes, I've found... Thanks, now it works!
Message Edited by kolan on 02-26-2010 10:28 AM
(3,787 Views)
Hi Kolan,
you might want to mark the thread as solved if your initial problem has been solved as you indicate. You might even want to consider donating a little kudo to menchar for kind assistance 🙂
Wolfgang
(3,782 Views)
vielen Dank, Wolfgang.
(3,778 Views)
