LabWindows/CVI
LabWindows/CVI RealTime Module Not able install.
I using CVI 8.1.0. When i try to install RealTime Module. I get an error message of
"LabWindows/CVI RealTime Module
You must have a minimum of LabWindows/CVI 8.0.1 on your machine for this installer to function properly."
Please advice. thank you.
(4,474 Views)
Hello, John.
The real-time module needs to be the same version as your version of CVI. If you have CVI 8.1, you can only use CVI RT 8.1. It looks like you are trying to install CVI RT 8.0 with CVI 8.1, and that will not work.
Looking at your screenshot, I agree that the message you got was misleading, since it says "minimum". I believe that the reason for the misleading wording was because for CVI RT 8.0, the CVI environment could not be 8.0. It had to 8.0.1, or later (meaning 8.0.2, 8.0.3, etc...). That's why it said "minimum". But after 8.0, "minimum" was removed.
Luis
(4,456 Views)
thanks for ur prompt response.
i unstalled CVI 8.1. and installed CVI 8.0. But it still the same problem.
(4,430 Views)
Hello Jong,
Did you install 8.0 of CVI or 8.0.1?
-Bob
(4,380 Views)
