LabWindows/CVI
LabWindows/CVI Message Creat Distribution Kit Error 26251
I get this message when I'm trying to make a distribution kit for my application :
Create Distribution Kit Error 26251:
Error Copying generated CAB file to build location because the location does not exist ,is not writeable, or has insufficient space.
 I don't think that it is a space problem  because I have 37.5Go used sapce and 31.7Go free sapce
enclosed a print screen of the folder attributes in witch i try to creat my distribution kit
Thank you for help
(3,757 Views)
Try changing the location for the Kit to c:\
It will tell you if the problem is in your location or it's a general problem...
Kobi Kalif
Software Engineer
(3,741 Views)
thank you for you prompt response
I tried and i get the same message so it seems like a general problem
how can i fix this problem
(3,730 Views)
Are you including the run-time engine in the distribution kit?  I have found a KB that suggests removing the run-time engine.  Let me know if that allows the build to complete.
AE KB 3QDE5RO1: Why am I Getting Errors When Building an Application Using Application Builder?
http://digital.ni.com/public.nsf/allkb/1717B1A92B71C78F8625709A006EC080?OpenDocument
Shawn S. | NIC
Instrument Driver/IVI PSE
(3,705 Views)
I removed the run time engine but i still get the same message and I still not able to build a distribution kit
I'm wondering if this problem can have some relation with user rights because our MIS has change some rihts on my PC and I'm not able
to know what did he change exactly
so did you have any other suggestions
to fix this problem
also please not that one month ago I'm able to build distribution kit
(3,688 Views)
kadi -
Which version of LabWindows/CVI are you using?  Also, what language is your version in and have you tried building a distribution of a small, simple program (maybe a shipping example at Help » Find Examples...)?  Please try that and let me know if you encounter the same error.
Shawn S. | NIC
(3,656 Views)
Also, you will want to change the folder settings so that they are not read only.  I bet changing this will allow you to build the distribution.
Shawn S. | NIC
(3,646 Views)
