LabWindows/CVI
LabWindows/CVI Excel Macro problem
I am using LabWindows CVI version 8.5 and am trying to call a macro in Excel.  The Excel file name has a space in it and when I call it (using the code below), I get an error (Exception occured).  The error number returned is -2147352567.  If the Excel file doesn't have a space in the file name it works.  What do I need to do?   I have looked on the support forum but haven’t found an answer.
Below is the function the Excel2000dem.c sample provided with LabWindows CVI that I modified to call my excel file.
// RunMacro
int CVICALLBACK RunMacro (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
HRESULT error = 0;
  switch(event)
    case EVENT_COMMIT:
      SetWaitCursor (1);
      // Application.Run "exceldem.xls!NewDataFromMacro"
#if(0)
      //original code supplied
      status = CA_VariantSetCString (&MyVariant, "exceldem.xls!NewDataFromMacro");
#else
      //This works but if the name is changed to “Macro Test.xls!MoveCell” it doesn’t
      status = CA_VariantSetCString (&MyVariant, "MacroTest.xls!MoveCell");
#endif
      error = Excel_AppRun (ExcelAppHandle, NULL, MyVariant, CA_DEFAULT_VAL,
                            CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL,
                            CA_DEFAULT_VAL, CA_DEFAULT_VAL, NULL);
      CA_VariantClear(&MyVariant);
      if(status<0) goto Error;
      SetWaitCursor (0);
      break;
Error:
  SetWaitCursor (0);
  if(error < 0)
    ReportAppAutomationError (error);
  return 0;
(3,848 Views)
Hey rgelbmann,
Try escaping the space--here's an example:
status = CA_VariantSetCString (&MyVariant, "Macro\ Test.xls!MoveCell");
Hopefully that will work. I suspect that when the CA_VariantSetCString function converts the string to a binary string, it's interpreting the space as a null character and therefore not saving the correct filename. Let us know if that doesn't work and we can look into other possibilities.
(3,836 Views)
Another possibility could be to embed quotes in the string, as you normally do when using filenames with embedded spaces.
status = CA_VariantSetCString (&MyVariant, "\"Macro Test.xls\"!MoveCell");
I also noted that Excel when making references to cells in sheets with spaces in their name embeds the reference in single quotes: e.g. 'Sheet 2'!A1 so you may try this way also in case the prededing ones are unsuccessful. Unfortunately I cannot test any of these suggestions now.
(3,832 Views)
Daniel-E
I tried that and the compiler is giving me the warning of " unrecognized character escape sequence '\' " and then fails.
(3,827 Views)
Roberto,
I tried your suggestions by adding the double quotes around the file name and I got the same result (exception erro).  However, adding a single quote did work!
Thanks for the suggestions!
(3,825 Views)
