LabWindows/CVI
LabWindows CVI: Bitshfting issue
I cannot understand why LabWindows refuses to shift bits at all; it pretends the command doesn't even exist when tracking with breakpoints:
int pattern = 1;
if (pattern == 255)
    pattern =1;
// I have other assignments here that do not involve pattern.
else
    pattern << 1;
// I have other assignments here that do not involve pattern and that work fine.
I'm at my wits end and the help file is providing no help whatsoever.  Given this is working just fine and dandy in XCode/gcc, I'm wondering why LabWindows refuses to do as it is told.  I can only speculate that bitshifting is done differently in LabWindows?
Any help would be appreciated.
(3,344 Views)
Figured it out.
I have to use a temporary variable to save the shifting result, that is,
int a = 0;
a = (pattern >> 1);
(3,342 Views)
You're right. You cannot simply shift your variable, but you must explicitly assign the result to it, the same as for incrementing it you'd have used "pattern += 4;" I don't remember now if "<<=" is a valid operator, but you can simply try it: the compilator will tell you! Smiley Wink
(3,334 Views)
Back in the office. Confirmed that assign left shift operator is good working in CVI. Smiley Happy
(3,329 Views)
