LabWindows/CVI
LabWindows 2020f2 install missing files
The LabWindows/CVI 2020 f2 install seems to miss installing some important files. I'm missing the cvi.exe file I would expect to find in the C:\Program Files (x86)\National Instruments\CVI2020 folder. There may be other files missing.
I've run the repair, and tried uninstall and re-installing the software. Is the distribution incomplete?
I have not yet tried installing an older version of CVI 2020 first.
(1,795 Views)
cvi.exe should indeed be in C:\Program Files (x86)\National Instruments\CVI2020... Some permission problem ?
(1,767 Views)
If it is, it is an unusual one. I'm running the package manager with (what should be) admin rights.
The installer gives no error messages. I don't know if there is an install log saved somewhere with any more details.
Comparing to the CVI2019 folder, most files and sub-directories that I would expect do exist, so the installer certainly has write permissions.
I cannot determine a commonality to the missing files. For example cvi.exe is missing but compile.exe exists. Same with .dll files. Some are missing but others were installed correctly.
(1,706 Views)
I wonder if it can be an antivirus problem: maybe it recognizes some files as new and quarantines them
(1,704 Views)
