LabWindows/CVI
LabWindows 2010 Compatibility with LabView RT 2011
Thomas,
Nick is going to be out for awhile, so I am going to pick up where he left off with helping you troubleshoot this issue. We are looking into some options for debugging this further, but in the meantime, I wanted to double check to see if you tried connecting with the firewall disabled.
Message 11 of 23
(2,661 Views)
Yes.  However, the firewall does not impact using CVI when the target is configured with LV-RT-10.0.  I only experience these problems when the target is configured with LV-RT-11.0.
Tom
Message 12 of 23
(2,655 Views)
Tom
Message 13 of 23
(2,655 Views)
Tom,
Could you send me a dump of your current connections of Service Locator. You can retrieve this by navigating to http://<target ip>:3580/dumpinfo? in a web browser.
Also, could you try switching your execution target (Run>>Select Execution Target for Debugging) to some other target, then switch it back to the target that is giving errors and see if another error pops up?
Message 14 of 23
(2,650 Views)
Infomation on current connections of Service Locator:
Service Locator URL
Mappings
URL Content
Main Application
Instance/RTServiceName
HTTP/1.0 200 OK
Server: Service Locator
Pragma: no-cache
Connection: Close
Content-Length: 11
Content-Type: text/html
Port=3079
National
Instruments/NI-RPC/Interface/158513d1-adcb-11d3-aa08-005004d131ee
HTTP/1.0 200 OK
Pragma: no-cache
Connection: Close
Content-Length: 15
Mapping=51700
National
Instruments/NI-RPC/Interface/f52d0817-1176-427c-9637-ae177aebd682
HTTP/1.0 200 OK
Pragma: no-cache
Connection: Close
Content-Length: 15
Mapping=62602
National
Instruments/NINetworkDiscovery
HTTP/1.0 200 OK
Pragma: no-cache
Connection: Close
Content-Length: 14
Mapping=1055
National Instruments/Web
Servers/NI System Web Server/http
HTTP/1.0 200 OK
Pragma: no-cache
Connection: Close
Content-Length: 14
Mapping=3580
When I select another target then try to come back to the target with the LV-RT-11.0 driver, I get the same error as before:
Tom
Message 15 of 23
(2,638 Views)
Are there any more items to try or is this the end of the thread?
Message 16 of 23
(2,614 Views)
Sorry for the delay, we were investigating an issue related to you mappings. I do have some more troubleshooting steps for you.
In the root directory of the RT machine there is a ni-rt.ini file. In that file there is a key listing the StartupDLLs. Could you send me that list? It should contain "c:\NI-RT\system\cvi_lvrt.dll". The theory is that this or one of it's dependencies is not properly loaded.
Message 17 of 23
(2,610 Views)
Attached is the file you requested.  I have also copied the contents of the ni-rt-.ini file below:
[SYSTEMSETTINGS]
Host_Name=ATOM-4826269F
Comment=00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Comment_Format=512
[TCP_STACK_CONFIG]
IP_Address=195.0.0.234
Subnet_Mask=255.255.255.0
Gateway=195.0.0.1
DNS_Address=0.0.0.0
[LVRT]
StartupDLLs=nisysrpc.dll;c:\ni-rt\system\mxsemb.dll;c:\ni-rt\system\taggerrt.dll;c:\NI-RT\system\cvi_lvrt.dll;sysstatepublisher.dll;c:\NI-RT\cvi\JAWS2LEAL.dll;
RTTarget.ApplicationPath=c:\ni-rt\startup\startup.rtexe
RTTarget.OlsonTimeZone=EST
RTTarget.TimeZone=EST5
CVIRealTimePort=3291
RTUseMutexOptimizations=True
SocketSendBufferSize=65535
SocketRecvBufferSize=65535
EnableCPULoadDisplay=True
LABVIEWRTDir=C:\ni-rt\system
CDIntervalTicks=55
WebServer.Enabled=FALSE
RTTarget.VIPath=C:\ni-rt\startup
RTTarget.IPAccess=+*
RTEnetRcvMode=2
RTCPULoadMonitoringEnabled=True
PATH=C:\ni-rt\system\;c:\NI-RT\cvi\;
[NVE]
MessageQueueUpperBound=100000
[STARTUP]
MainExe=/ni-rt/system/lvrt.dll
EarlyStartupLibraries=nirtdm.dll;nimdnsr.dll;C:\ni-rt\system\lvuste.dll;C:\ni-rt\system\tsengine.dll;C:\ni-rt\system\nisl_emb.dll;RTWebServer.dll;niDiscSvc.dll;
[SUPPORTED LOCALES]
english=L1
[MDNSRESPONDER]
mDNSDisableAnnouncement=0
mDNSDisableDiscovery=0
Message 18 of 23
(2,598 Views)
Thomas,
Do you have the files /ni-rt/system/MSVCR71.dll and /ni-rt/system/MSVCP71.dll on the RT target? Those are the two required dependencies for the cvi_lvrt.dll.
Message 19 of 23
(2,587 Views)
The files /ni-rt/system/MSVCR71.dll and /ni-rt/system/MSVCP71.dll are on the target.
Tom
Message 20 of 23
(2,580 Views)
