LabWindows/CVI
LabView to LabWin CVI conversion
Has anyone ever tried to take a LabView state machine written application then tried to convert it over to a Lab Windows CVI platform? The test system consists of a single NI-232/16 Serial Communications card, an Agilent 34907 Scanner system, and an Agilent E3633A DC Power Supply.
Do any conversions applications exist within NI that might accomplish this?
(3,161 Views)
There aren't any conversion tools to convert LabVIEW G code into CVI. If you are using LabVIEW 6.0 or above with application builder, you could build your VIs into a DLL and call them from CVI. You could also launch your VIs from CVI through ActiveX automation. See the example program under cvi\samples\activex\labview.
Best Regards,
Chris Matthews
(3,161 Views)
