LabWindows/CVI
LIN diagnostic testing
I am getting a status = -1074388925 response from the ndOpenDiagnostic() function.
Am I missing something? Should I be using “ndOpenDiagnosticOnLIN()” function ? but I get -8008 when I use it.
Using the following:
LabWindows 2015
USB-8476 LIN interface device
Automotive Diagnostic Command Set -  revision 16
Code:
#define MasterRequestFrame  ""  // "" takes the default value "MasterReq"
#define SlaveResponseFrame   ""  // "" takes the default value "SlaveResp"
TD1 DiagStruct = {0,0,0,0,0,0};
WriteData[0] =  0x62;
WriteData[1] =  0x03;
WriteData[2] =  0x22;
WriteData[3] =  0x01;
WriteData[4] =   0x00;
WriteData[5] =   0xFF;
WriteData[6] =   0xFF;
WriteData[7] =   0xFF;
status = ndOpenDiagnostic (“LIN0”, 10417, 0, 0x3c, 0x3d, &DiagStruct);
//status = ndOpenDiagnosticOnLIN (“LIN0”, 10417, 0x62, MasterRequestFrame, SlaveResponseFrame, &DiagStruct);
//ndStartDiagnosticSession           ?????
  status2 = ndDiagnosticService (&DiagStruct, 1, &WriteData, word_size, &ReadData, size_word);
(2,893 Views)
Hi, Dennisatwork!
Took me a while to track down the details for error -1074388925:
The CAN Object name is invalid or unknown.  Solutions: Verify that you are using the
syntax specified in the NI-CAN documentation.
I am looking at page 280 of the Automotive Diagnostic Command Set API for C manual.
Automotive Diagnostic Command Set User Manual
http://www.ni.com/pdf/manuals/372139g.pdf
I recommend reading the details under Input for ndOpenDiagnostic as well as ndOpenDiagnosticOnLIN.
Check your first arguments (CANInterface) of both these functions, make sure they match/are configured correctly in NI MAX. I see that you tried using LIN0 for the first argument of ndOpenDiagnostic, that is not correct according to the manual.
(2,867 Views)
the USB-8476 device is not XNET compatible and ADCS needs XNET.
(2,853 Views)
