LabWindows/CVI
LED tristate
How to set LED indicator to three colors? Dark green (default), Green (Off) and RED (ON).
No callback used, only postUI message to set the led to on or off state.
Thanks.
(4,067 Views)
Accepted by topic author sonotk
you almost gave the answer yourself Smiley Wink : I see two possibilities:
1) Use SetCtrlAttribute (, , ATTR_DFLT_VALUE, ); SetCtrlAttribute (, , ATTR_OFF_COLOR, ); or SetCtrlAttribute (, , ATTR_ON_COLOR, );
2) Since you are using the LED as indicator I see no functional difference between ON and OFF, so you could define your own function SetLEDState ( 0 / 1 / 2 ) where you simply change the ON color depending on your state, something like
int SetLEDState ( int panel, int control, int state )
    switch ( state )
        case 0:
            color = VAL_DK_GREEN;
            break;
        case 1:
            color = VAL_GREEN;
            break;
        case 2:
            color = VAL_RED;
            break;
     SetCtrlAttribute ( panel, control, ATTR_ON_COLOR, color );
(4,063 Views)
Another alternative is to use a picture ring loaded with three LED images with the proper colors and associated values: the desired color can then be obtained with a simple SetCtrlVal (panelHandle, PANEL_LED, color); call
(4,054 Views)
