LabWindows/CVI
LED Indicator
Sorry, I keep hitting space bar...
I'm using LabWindows/CVI and put a LED to act as an indicator.
I am generating a discrete pulse and I want the indicator to turn on when it is outputing my waveform.  I have a "Generate" button to initiate the pulse.
I put the indicator lines in the Callback function for the Generate button.  It goes something like this:
if(event == EVENT_COMMIT)
  SetCtrlVal(panel, AO_PANEL_LED_2, 1);
  for(i=0; i<300, i++) //updating 300
     AO_VWrite(1,1,waveir[i]);
SetCtrlVal(panel, AO_PANEL_LED_2,0);
I am assuming that the indicator to turn on is 1 and the indicator to turn off is 0.  Is this correct?
(3,856 Views)
Yes, your assumption is correct, but you may need a ProcessDrawEvents () to update the panel before entering the for loop, otherwise your led won't light.
(3,845 Views)
THANKS!  WIthout the function it wasn't working, but I added it and it appears to work great!
I
(3,838 Views)
