LabWindows/CVI
Keithley 2420 GPIB LabWindows CVI SCPI/Driver help
Hello everyone. I have a Keithley 2420 source meter. I would like to only use it to "READ voltage" in a LabWindows CVI (2009) program. I am very new to the programming in CVI but am fairly experienced in programming in general. I looked for "Drivers" for Keithlety 2420 but there is no drivers on the web available for LabWindows CVI 2009 for it. So I decided to just use SCPI commands. The commands for this instrument can be found in the manual here (PDF) under chapters 16 and 17. I am using an Agilent 82357A USB to GPIB cable to connect to this device. My problem is that I don't know how to start this. What are the steps to write these commands? How can I communicate to the device via LabWindows CVI? I believe there should be some sort of initialization first... How should I do that? How can I send commands and "READ" the response? If anyone has some sort of source code for this I would greatly appreciate them sharing it or a portion of it with me.
Any input would be greatly appreciated!
Message 1 of 14
(7,081 Views)
Keithley lists drivers for LabVIEW, for CVI, ad for C/C++, see e.g.  here
NI lists a driver here
Both sides could easily be found using a Google search for 'Keithley 2420'
Message 2 of 14
(7,071 Views)
Thanks. Got the driver.
Now I am trying to "initialize" the device and get the error saying Undefined symbol '_Ke24xx_init@12' referenced in "Form.c". What does this mean? I don't even have that symbol in my "Form.c" file. All I have is:
Ke24xx_init ("GPIB0::23::INSTR", &Ke2420Model, &Ke2420Handle);
//Ke2420Model and Ke2420Handle are static int.
Message 3 of 14
(7,019 Views)
I think I'm missing the C file of my driver... Does anyone have Ke24xx.c here?
Message 4 of 14
(7,014 Views)
The driver that I have has only the following files:
Ke24xx.h
Ke24xx.fp
ke24xx.lib
Isn't it supposed to have also a .C file?
Message 5 of 14
(7,008 Views)
You need to add the Ke24xx.lib file to your project - that will fix the error. This driver doesn't ship with the source file (ke24xx.c) if you want this request it from Keithley: IntrumentDrivers@keithley.com
Message 6 of 14
(6,998 Views)
I just added the driver to my project. Now it shows on the side as one of the files. I saved all, but still get the same error. I am including a screenshot so you can see my code...
18055i3B0F71C2B5CC887A
Message 7 of 14
(6,972 Views)
The screenshot is very blurred but I get the jist of it and it looks good.
1. Hover over all the files in the tree and you should get a tooltip which shows the path to the file. Make sure the file is at that path location.
2. I believe in LabWindows you can select Broland or Micorosoft as the project type. Check what this is set for and make sure the ke24xx.lib is the correct one as there is one for MS and one for BC.
Message 8 of 14
(6,945 Views)
The first step is done. All the files are in correct paths. As far as the second step, how can I change the project type from Broland to Micorosoft or vice versa?
Message 9 of 14
(6,906 Views)
CVI2009 does no longer support Borland, so no reason to search Smiley Happy
Message 10 of 14
(6,900 Views)
