LabWindows/CVI
Issues after compiling code with CVI 2015
Hello
I am using CVI 2015,
I am developing software for test equipment, after compiling the source code (assume its unit 1), whenever i build the source code, I am including Test executive source code (its similar to test stand User Interface), we have (test executive.exe) will be created.
later i run the test executive.exe and select the sequence file for testing unit 1. it works fine. but it will not work with unit2 or unit 3 sequence files. if I compile unit2 and create test executive.exe it will work only for unit2 not for units.
can any one help on the same?
thanks
Message 1 of 1
(2,292 Views)
